nola mike
- Apr 22, 2009
- 5,850
Certainly sounds like a mechanical issue if 2 injectors from each side are fired separately from the other 2. But the voltage thing doesn't make sense thenMy injector plugs are numbered and connected correctly. 2, 4, 6 and 8 on the starboard side.
I will see if the voltage readings ever change.
I will also look to see if any colors match. Maybe the banks are really different than just evens and odds. The spark plugs were definitely only noticeably black on the even side.
That might be helpfulAgree the difference in voltage might be the static state of the ECM, don't know, just guessing. Would be interesting test to remove on of the injectors and see if the injector would fire just with the key ON. Might try on/off a few times to see if things change
