Ok heading to a beautiful mountain lake in the middle of nowhere Montana for the Fourth. 1994 master craft PS190 w indmar v8 fuel injected inboard is waiting. Gets professionally winterized every year.
owner who is already there says it will not crank or start.
battery good
blower bilge heater will turn on.
Stereo gauges and ignition do nothing. No click no crank no joy.
Kill switch lanyard is attached and it’s in neutral. He can’t hear fuel pump pressurize but I don’t know if you should be able to on that early an engine?
it ran recently. I’m in Washington so can’t see it yet but am thinking bad starter or coil or fuel pump wouldn’t affect stereo or gauges, right? I’m thinking wiring to or from ignition key switch area or that switch itself may be the culprit?
Any thoughts or ideas? I’ve told you all I know but can get follow up info. Thanks in advance!
battery good
