I have a 2009 Bayliner 175 with 3.0l mercruiser TKS engine. I have never had an issue with it before but yesterday I took it out for the first time this year. It started and idled fine as usual. I took it up to full speed for about 5 minutes to get to our fishing spot and then cruised at idle speed. Everything was fine for about another 5 minutes and then the engine stalled and died. I started it back up but it would only stay running at 3/4 throttle and above. So I raced back into the marina and when i slowed down to maneuver through the marina it kept dying again. I parked it in my spot in the marina and started looking at the engine to see if I could see anything obvious that came off or unplugged, but there was nothing noticeable. I took off the distributor cap that I replaced early last year and noticed the "anti corrosion" coating was flaking on the pins under the cap. I cleaned it off a bit with a screw driver and it started much easier and even idled for about 10 min. I turned it off and then restarted it right away and it would not stay running again. I left it for the night and spent the next few hours on google and this forum.
After some research it sounded like the TKS module might be the fault as it originally started after the warm up period. I went back to the boat and started it cold. It started and I could hear the loud hissing from the TKS module. I struggled to get it to run long enough, but after about 4 minutes I felt the back of the TKS module and felt that it was warm and then about 2 minutes later you could hear the hissing go away about 90%. I took off the spark arrestor and found the port that the TKS blocks but there was still a tiny bit suction coming from it. Is that normal?
Next I could get it to start again but as soon as I started to give it throttle it would stall again. No sputter or anything, just rev up to about 1800 rpm and then immediately stall, like someone turned off the key. I am thinking this is a fuel issue?? or airflow?? I was pretty sure that I had drained the fuel tank at the end of last season but then when I went to fill it up this spring it only took about 20L or so.
I have ordered a new distributor cap and rotor, plugs, wires and fuel filter and will try probably drain the tank and refill with new gas and a can of seafoam. Any other suggestions to check? should I pull that TKS module off and clean it anyway?
Any help would be greatly appreciated.
