I am in the process of exchanging my SX-m lower (on my boat) with the lower assembly of a dp-sm outdrive which I have on a stand in the garage. I have removed the 4 nuts and two bolts on the dp-sm outdrive needed to drop the lower, but the two halves will not seem to separate. I’ve tried tapping with a rubber mallet while I have the entire outdrive slightly suspended from a eye bolt screwed into the oil dipstick hole. I have liberally sprayed “aero kroil” penetrating oil on the areas where the lower separates from the upper assembly. So far, no luck. It hasn’t budged in the slightest. It should be noted that the dp-sm outdrive was from a trailer boat that was used in saltwater and the front prop was stuck on the prop shaft so badly that I had to cut it off (from saltwater). Any suggestions????
