Another ‘No Spark’ questione
Merccoper
So I’m continuing my search for the no spark issue on my 1996 40 hp 4 cylinder mariner magnum electric start. I say “continuing” because I did the tests with an unpredictable meter the first time. Anyhow, this is the summary:
No spark on any cylinder
Stator ohm’s tests ok
Trigger ohm’s tests ok
Ignition coil ohm’s tests ok
Ignition key switch tests ok
There is no Mercury tilt stop switch (that I can tell!)
So....I don’t have a DVA to do the voltage tests. But, from the tests above, am I safe to say that it is the switch box? Could it be anything else?
Thanks!
Disconnect the kill wires at the switchbox to be sure those are not inadvertently grounded by rubbing against the cowling or engine.
Merccoper
Thanks for the input Chris. There isn’t a kill switch on this model (unless I’m missing something)
Merccoper
Take the blk/yel wire off switchbox and check for spark...
Thanks for the additional diagnostic. The are two black/yellow wire on the same post. When I remove them, should I keep them together or should I separate them?
Thanks again for your help!
Merccoper
Ok, I disconnected the wires from the switch box and tested for spark. No spark when they are connected together or not.
Merccoper
I have ordered a new switch box. Fingers crossed this is the issue!
Merccoper
Thanks!
I’m back!
So I installed the new switch box but still no spark.
Any other suggestions? This is driving me nuts!
