Ok, alpha one gen 2. Everything ran fine last year, this year before getting it in the water I replaced the impeller.
Everything runs great on muffs in the driveway, but got it on the water and unless I'm giving it a lot of throttle it stalls. If I am going relatively straight and at a higher throttle it seems to run ok, but I turn or lower throttle and it stalls. Definitely added resistance to the prop seems to stall it.
What I did when replacing impeller:
I removed the upper and lower unit, so I could work on it in the garage. Replaced all seals etc, all went fine, so I thought. The one thing I didn't do that I am now reading is that I did not bungee my prop in "drive" while reinserting sterndrive. Everything went together easily and lower unit drive shifter is in the groove it is supposed to be. Is it possible that I am off by a spline or so when I reinserted the sterndrive and it's causing this issue, or is it more likely something else is going on?
Thanks for any insights.
