Let me clarify. It does open the butterflies but it seems like a very long travel before they start to move. I’m not sure how much travel the handle should have but it’s from 1-3 o’clock at leastIs the Throttle Cable hooked up? If so, does the Linkage move as the Lever is moved?
I haven’t removed the flywheel but I see the timing plate movingWell, the carbs stay fully closed until very late in the Throttle, almost all of the timing Advance happens before they even move a fraction from fully closed. Is the Ignition Plate, under the Flywheel rotating when the Throttle is advanced?
