watrski4ever
- Jun 28, 2011
- 17
I have a 1997 4.3 V6, carbureted engine with a Thunderbolt V ignition system that has been dying after a few minutes of running perfectly. So far it has always started back up and runs perfect again until it dies again. I initially suspected ignition malfunctions because of the way it stopped, without spitting or sputtering or bucking, the things I would think would indicate fuel...but I was wrong. After checking spark as it died with an in-line spark tester, I could see it spark until it stopped.
So now I'm looking at fuel issues. Does anyone know if this engine is equipped with a low oil pressure cut-out? The oil pressure is good, but if the sender is malfunctioning, it may be sending a signal to the electric fuel pump. Sound plausible?
