BWR1953
- Jan 23, 2009
- 6,523
Regarding the bottom carb, which was less affected at first by the PT treatment, I'm wondering if a carb problem could give that kind of indication?The PT application and no water run time does make it tough to read the plugs. You said that spraying the PT in the bottom carb didn't affect the idle and the 2 bottom plugs don't have the distinct light brown around the electrode. Something isn't right with the bottom 2 cylinders.
Addressing the elephant in the room, the first thing to do anyone says is run a compression check and with your compression numbers being 70 ish, I really don't know how much time and money I would exert on the motor. Personally on my old motors I have no problem sinking money into them if the numbers are above 120, I know I can get many years of use on the cheap before they start to loose their will to live.
I know the feeling is that the motor has ran really good up until now but with low compression numbers it's on borrowed time to where no amount of new parts will make it run better short of an internals rebuild.
And yes, I'm definitely concerned about throwing money and especially time, at this engine if it's not worth saving. Both of those commodities are significant for me.
I do have an option if the 50 is Tango Uniform... I could use one of the 70HP blue band engines from the Chief project and literally bolt it right onto the KF. But that's a no-no in this state. Still worth thinking about though.
