Thirsty Endgrain
- May 30, 2020
- 254
Hi all,
New to me '02. Just getting everything all tested and worked out before I put it on the boat. When I turn the key on it's a constant alarm beep. Does not go off no matter what. From my research on this model it's either high temp, or low oil pressure warning. Since it stays on no matter what, even before I've tried to start the engine I think I can rule out low oil pressure?
Disconnected both sensors, doesn't make a difference, alarm stays on. Checked for continuity on the oil pressure sensor wire, none, so I think it's not grounding out.
The black wire to the temp sensor is grounded, and the black and yellow is not, which I'm assuming is normal.
Does this equate to either a problem at the CDI, or at the remote?
Thank you!
Thank you!
