Flanagani89
- Jul 25, 2022
- 6
Hey all
New to the forum and boats in general.. Hope you guys can give me some insight, I'm close to losing it on this thing
The impeller went the third time I took out my new to me force outboard, resulting in the motor getting quite warm, and myself having a very long day getting it back to the launch. Noticed that the head had a very small leak.
The impeller was swapped out. Head gasket was ordered, I was thinking this was going to be a simple fix.
New gasket goes in. I ordered the manual so I had the torque sequence (didn't have an inch-lb wrench though). Water was now gushing around the gasket.
Second head gasket ordered. Figured I was an idiot and didn't check to see if anything was warped. Feeler gauge showed that the block was good.. head was slightly warped, so I did the sandpaper trick and got it pretty good. Second gasket put it, fired it up and... it still leaked
Ordered a new head. While I was waiting I tried a third gasket, this time with some sealant. Huge improvement, but still leaked.
... got the new head in. Put it on without the gasket and it looked super snug on the block, no gaps whatsoever... Put the fourth gasket on (this time with new bolts!) Torqued what bolts I could get to and you guessed it, still leaking.
I feel like I'm missing something obvious here. The only thing I can think of is the gaskets being faulty? They are Serria replacements. I have a fifth one coming.
Thoughts?
Thoughts?
