My generator keeps shutting down on my 260 Sundancer after a few minutes of operation.
I've had the carburetor rebuilt and set. My sparkplugs, fuel filter, fuel lines have been flushed and water pump impeller has been changed and the previous one did not have any broken vanes at all. I have also checked the oil in the unit and it is showing the correct level of oil with the oil cap not screwed in all the way.
My first guess is that it is not drawing in enough water into the generator causing it to shut down... It does radiate some heat after running for a few minutes and definitely seems as if it is overheating. I'm looking for pointers what to check on the cooling system to solve the problem. Generator has low hours and has not been used much 188 hours... It was used much more by previous owner however it's likely been 2-3 years at min.
