f.i.SHERMAN
- Aug 1, 2022
- 3
Hi, live in Ontario Canada. I am looking for a flywheel for the above engine. The part # is 43817409. I am having a hard time sourcing this, new or used. Any ideas?
Thanks for this. I was on eBay and saw all of the sport jet drive links. I wasn’t sure if they would fit (my engine isn’t a sport jet type of engine - sorry if that sounds naïve). Plus these links all say that the flywheel (part #4) is unavailable. The first link looks positive, but the numbers don’t match the part number of my flywheel. Not sure how I would check for compatibility?This list is from boats.net it covers everything that the flywheel fits.
eBay has one listed that might fit??? https://www.ebay.com/itm/125436399198?hash=item1d34978e5e:g:PvYAAOSwm55i4gQp
Mercury Sportjet Jet Drive 120HP 120XR Sportjet Jet Drive 0E145580 THRU 0E151579 Electrical Components
Mercury Sportjet Jet Drive 95HP 95XR Sportjet Powerhead 0E203000 THRU 0E315904 Electrical Components
Mercury Sportjet Jet Drive 95HP 95XR Sportjet Powerhead 0E141089 THRU 0E202999 Electrical Components
Mercury Sportjet Jet Drive 120HP 120XR Sportjet Powerhead 0E315905 THRU 0E341982 Electrical Components
Mercury Sportjet Jet Drive 120HP 120XR Sportjet Jet Drive 0E151580 THRU 0E288445 Electrical Components
Mercury Sportjet Jet Drive 120HP 120XR Sportjet Powerhead 0E203000 THRU 0E315904 Electrical Components
Mercury Sportjet Jet Drive 95HP 95XR Sportjet Jet Drive 0E145580 THRU 0E151579 Electrical Components
Mercury Sportjet Jet Drive 120HP 120XR Sportjet Jet Drive 0E288446 THRU 0E344999 Electrical Components
Mercury Sportjet Jet Drive 120HP 120XR Sportjet Powerhead 0E141089 THRU 0E202999 Electrical Components
Mercury Sportjet Jet Drive 95HP 95XR Sportjet Jet Drive 0E151580 THRU 0E288445 Electrical Components
Force Outboard 90HP 0E138600 THRU 0E202999 1996 Electrical Components(Flywheel And Relays)
Force Outboard 90HP 0E203000 THRU 0E287999 1997 Electrical Components(Flywheel And Relays)
Force Outboard 120HP 0E203000 THRU 0E287999 1997 Electrical Components(Flywheel And Relays)
Force Outboard 120HP 0E138600 THRU 0E202999 1996 Electrical Components(Flywheel And Relays)
'96 Models are tricky as they were already Merc. ignition/flywheel and also the last time a modification was made to the ignition till it finally died in '99Look for late model engines with the CDM modules. The flywheels have a different hub size and magnet arrangement for the trigger and coil.
The older flywheels have a flat top and the one you are looking for has a raised ring around the hub that is threaded for the puller.
The earlier flat topped flywheel has a smaller hub and goes with the CDI modules.
Thank you! How did you determine that?9008A36 is the # you're looking for
jerryjerry05 provided you with all the info/links.Thank you! How did you determine that?
I don't think thats the correct one![]()
Flywheel From 115 HP Mercury OUTBOARD Motor 2005 for sale online | eBay
Find many great new & used options and get the best deals for Flywheel From 115 HP Mercury OUTBOARD Motor 2005 at the best online prices at eBay! Free shipping for many products!www.ebay.com
Than the part# and description in the ad is not correct, although it should; check the # stamped in the flywheel 261-9007-c2 is for Mariner 60 HP or othersLooks correct to me as it has the raised ring around the hub internally threaded for the puller.
The early one is flat on the top. see post above.
