Al Lounsbury
- Aug 21, 2022
- 6
So this is a 2+2 engine. That is under approx. 2500 rpm, only 2 cylinders in use, over 2500 rpm then the bottom two kick in with the high speed jet in the carburetor.
Now the problem: When the engine is cold (first time started during the day), when I accelerate to Wide Open Throttle (WOT), as the bottom 2 cylinders start to cut in, it's like an on/off switch and someone is flicking it for a good minute. And it's a hard cut out/cut in, that is no power then full power. This goes on for a good 1-2 minutes then after that - totally no issue. Everything works as expected, hit the hammer and all four cylinders kick in immediately.
My initial guess at the problem was the two check valves for the high speed cylinders since it was a hard on/off and maybe the check values were sticking, but alas replaced them and NOT the problem. In fact I think the newly design check values dropped 100 rpm off the top end, but not changing back to original until problem solved. And plugs have been replaced with new ones twice, no change.
So now I'm thinking it's one of the CDM's that maybe collect some moisture overnight and until flushed out - it's just intermittent? Or is there any chance it's the switchbox or trigger assembly? At this stage, looking for ideas, since just not sure. My next guess is to replace the bottom 2 CDM's but truly would love some additional thoughts and just hoping someone has seen this problem before.
And if there is anyway to troubleshoot this situation better, let me know.
Regards Al
Regards Al
