Hello all,
I have an issue with my IAC opening the air flow to max on Idle. My boat neighbor has a Tech Mate pro and we can watch the IAC position reading eventually (after about 3 minutes) go to "0" which is allowing maximum airflow through the throttle body bypass chamber.
I replaced the IAC sensor and still have the same issue. It is causing the motor to rev up to about 2k RPM on the gauge and 1.5k RPM on the Tech Mate and also creates a horrible noise while the air is traveling through the bypass chamber.
In my simple mind, something is telling the IAC sensor to open up all the way and I am not sure where to look next.
Thanks in advance for any help.
Dave
Dave
