vroom ZOOM
- Aug 15, 2017
- 435
Hi, this one has me stumped. Seems like im better at diagnosing efi motors than the carbed ones. I don't know the exact model number, because the sticker is long gone, but it is a 1994 7.4GL. The ignition system is NOT the EST, or the EEM version. Here is a pic of the motor:
This thing backfires like an AK-47 as soon as you give it any throttle. When cold, it isn't so bad, but it still stalls with a loud pop out the carb. Sometimes it pops and stalls, then it pulls smoothly for a second or two, then starts popping again. I checked the carb and float etc thinking it was a lean pop, but everything checked out ok, and all jets were clean. After putting back together no change. It will idle forever, no pops or anything, although it does seem to miss a tad. One time when it started popping, it shut it off with the key and drained the carb bowl - it had quite a bit of fuel, so therefore the lift pump is working ok. After taking out one of the plugs (others were hard to get to), I saw it was all sooty and black... definitely not lean looking.
Fuel wise, I think I checked everything that could be problematic. The thing is, I'm not too familiar with this ignition system, so I could use some advice. I looked at the cap for carbon trails, but that was impossible to find because it is black. any advice on what to look for? I'm starting to think valve springs? I really don't want to pull the valve cover if I don't have to.
Here is a video of it running at idle:
video when it backfires:
