I purchased a 1990 celebrity Engine # 0D395753 I thought was close to running condition, but after carb replacement, starter, coil, wires and plugs ,cap and rotor , and ignition sensor I have no spark. I am asking if someone might know how to 1 show a wire diagram for the tether safety switch it has four terminals only three are used and 1 terminal has a double purple it shows A,B on switch? Temporarily jumped to get 12 V to the coil. Although I have 12v at both terminals on coil I believe that's ok ? And I am not sure I wired it right , both green/ White wires 1 from module,1 from shifter safety switch connected the G/W to distributor Red/ W to module black grounded. the only wires on coil are two purple on pos , and two greys on neg . sorry to be long .
