Engine timing 55 Evinrude fleetwin 7.5
doors67us
Hey all.im wondering what the timing procedure on my 55 fleetwin,don't have a manual for it ,any input would be great.Jim
When you set the breaker points at 0.020" the spark timing will be correct.-----There are no other adjustments except for throttle plate opening at the correct time.
doors67us
Ok ,and how do you do the adjustment on the throttle plate?what's the procedure?
Crosbyman
the cam follower or roller should just line up on the mark on the Cam with the throttle handle on START .
if not loosen the 2 bolt hold the cam under the FW and adjust accordindly.
doors67us
Thanks for the information,my flywheel doesn't have any marks on the sides ,like in the video, only thing it says is top on the top of the flywheel?
Your flywheel does have timing marks !!----Look for them.----Throttle at idle.-----Put piston to the top.-----Look for a mark / notch near those 2 vertical marks on magneto plate.
doors67us
Ok guys thanks again for all your assistance,this fourm is fantastic!!
doors67us
No not yet,I'm going to look at it later this afternoon, hopefully I'll find them ,and get it straightened out šŸ¤ž
doors67us
Only marks I see is the ones where the slot is for the rope nothing else anywhere,one mark on opposing sides
Turn flywheel over and look for 2 notches on bottom edge.----They will be 180 degrees apart.----I have never seen one of these flywheels that did not have the 2 marks !!
Crosbyman
one notch or a set of notches will be in line with the FW KEY slot
if you do not have any... make some :) 180 degrees aprat on the rim
