93 Johson 150hp fuel issue
Robdean
Remember, the idle jets, needle and passages are in the throttle bodies. They need to be cleaned as well.
If i take out the idle jets, needles in the throttle bodie will i need to adjust them when reinstalled? Just preparing for pulling them.
Yes, you would need to adjust them. However, on that motor, there should be a cover over the idle needle. You can remove the cover, clean the idle needle and passages and then install the cover, without removing the needles.
Robdean
saltchuckmatt
Cool i am looking for them and the cover now. I am looking at the exploded view and cant find either. https://www.marineengine.com/parts/...ohnson&section=Carburetor+And+Intake+Manifold
Watch this video. Motor is slightly newer (96) and different HP (150) but I believe everything is similar if not exact. It shows the throttle bodies (1/2 way through and the end of the video) and the covers.
It will definitely show you what your up against with the plastic carbs and the tricky seals.
Now hopefully others will watch and tell you what he did wrong....which I'm sure is plenty.
Hope this helps.
havoc_squad
Issue #1 spotted on the first video. If the parts schematic for your model's carb does not show the thick washer/gasket for the needle seat, do NOT put one on it.
The motor is going to starve itself for gas because there isn't any way to get the float level horizontal without seriously messing up the float adjustment more than it should be.
That washer wrongly reduces how much the carb bowl can intake by lowering the needle seat more than it should be.
Items 4 and 9 are the screws for the cover over the idle jets and needle. They do not show the cover or gasket for some reason.
flyingscott
Get a good manual because the calibration pockets also need to be cleaned. Those carbs are not hard to work on. Factory manual ONLY!!!!
oldboat1
I disassemble all carbs big and small, and soak in lacquer thinner for a few hours. Then clean every opening and orifice with soft wire and finish with carb spray, using the plastic nozzle to direct and add more pressure. I leave the jets in place and clean with soaking/soft wire/spray. Removing them can easily do damage. Likewise, I leave most of the linkages in place and soak with the rest.
Robdean
Hope this helps.
Thank you!!!
saltchuckmatt
Thank you!!!
The throttle bodies for your year and the video year motor have different part numbers so not sure everything will be the same.
Lots of good info either way so good luck to you....hope it all works out.
Robdean
Thanks everyone that helps a lot. Looks like after watching the videos i need to also get 1 large gaskets for the one side of the throttle body since it need to also come off to get to the idle jet port for cleaning. You are right this gets costly.
