Johnson vro 225 86'What motor does that beast got.
So which one did u order ?So over the weekend ended up gluing 3 pcs. of left over teak to finish the port side teak trim under the windows. Looking pretty good.
Also ordered a new remote controller for shifter. Will have to play with the wiring or get a harness adpt. to match to to the ole VRO.
The crazy is you can buy this from $500.00 to $167.00. Same darn thingy.
Yes, Sir I did.And you worked with it you sly devil.
I used it for patterning the eva foam decking, its basically plastic with a string grid pattern in it. It lays well and is transparent for easy marking with a felt pen.Anyone ever use this material to template for fabric?
Good/bad,...? pros, cons
Has anyone used this pro/cons?
Dura-Skrim® Patterning Material 74"
A lightweight clear plastic sheeting that works great as a patterning material.www.sailrite.com
