Re: Fuel Gauge Broken?
1. Make sure all the connections are solid.<br /><br />2. Put an ohm meter across the sender terminals. Move the float arm up and down. You should see a steady drop and rise in ohms with the sweep of the arm.<br /><br />If the sender is OK, it's the guage.
