Have you seen this ? Had a quick look. I’m case it helps. Go to page 253. You can scroll down without downloadingSame alarm. No other alarm present
Volvo Engine EGC Diagnostic | PDF | Motor Oil | Ignition System
Volvo penta egc dtc codes
Yes i have this version and also an updated version. I followed the procedure with no successHave you seen this ? Had a quick look. I’m case it helps. Go to page 253. You can scroll down without downloading
Volvo penta egc dtc codeswww.scribd.com
Ah. Got you. Got to be a simple one you’d think eh. Especially being common to both. Any sign of water intrusion at the dash end local to the issue ? Can’t be at engine end you’d think. Be rare chance if it affecting so widely a locationYes i have this version and also an updated version. I followed the procedure with no success
I didn't see any water because the two buzzer are in a very protected area. What i am going to check tomorrow is the wiring. Looking at the schematic it is very simple (now that i have the correct one). One positive from key to buzzer and a negative connected to the ECU. I already checked the negative.Ah. Got you. Got to be a simple one you’d think eh. Especially being common to both. Any sign of water intrusion at the dash end local to the issue ? Can’t be at engine end you’d think. Be rare chance if it affecting so widely a location
Similar to what I was eluding to with the mercruiser inherent errors that aren’t actually there. That’s one of them on that too, I’m sure.Problem solved!
It is difficult for me to explain the process in English but I will try.
Basically the Volvo Penta diagnosis is WRONG!
the dct 1642 is not real.
To recap, twin engine installation with EVC MC .
I disabled the multi sensor on both HIU in order to work separately on each engine.
Then i discovered that the fuel tank is not connected to the HIU but directly to the analog instrument on panel.
Because the engines have a mechanical control of power and not electronic there is no need for a interconnection between them.
Now i have NO FAULT and engines are running perfectly
