Play in driveshaft
maineiac5586
Master Chief Petty Officer
I have 2 lower units. One is a v6 lower unit one is a v 4
I noticed they both have play when wiggling driveshaft side to side. Noticed with and without water pump and housing either installed or removed. Gear oil looked fine. I pressure tested the v6 lower and couldn't get over 2 psi as I hear air leaking from driveshaft area. I have only worked on 60 hp and smaller omc and never noticed any play. Does this suggest something is wrong with these 2 lower units?
Some gearcases have 2 piece driveshafts. They have a junction, just above the driveshaft bearing, and have some wiggle, when not installed. The crankshaft holds the top of the driveshaft, when in use.
There is a seal on the driveshaft. It sounds like yours's is leaking.
Agreed on the 2 piece driveshaft.-----A good shop might have a fixture to hold driveshaft in the correct position for a pressure test.
maineiac5586
****. I just sold the v6 gearcase as a parts only item on ebay for 200.00 because I thought something was wrong with it. Oh well someone got a heck of a deal. Thanks guys for the info I appreciate it
