Yeah I pulled it open and it is exactly what you think it is brackish Brown water and what may or may not have been bosselwood at one point in time more than likely I'll have to take it all the way down to the hole any idea on the dimensions of the stringers I'm new to this and I've done glass work before but never on a boat workPeel it open and take a look
Specs for stringers doesn't exist
Transom most likely 2 layers 3/4in plywood, possibly a 1.5in single layer of plywood
Thank you for the informationYeah I pulled it open and it is exactly what you think it is brackish Brown water and what may or may not have been bosselwood at one point in time more than likely I'll have to take it all the way down to the hole any idea on the dimensions of the stringers I'm new to this and I've done glass work before but never on a boat work
As soon as I get back to the house I'll get some picks thanks for the help"Balsa Wood" . . .
Most production boats have plywood structures . . . Balsa wood is typically used as coring in decks or hulls.
The nice thing about restoring a boat is that you get to decide what materials to use in the rebuild. Most folks use plywood (exterior grade or marine . . . either will be fine). If you want to get fancy, you can go for foam core stringers . . . most of the strength needs to be in the fiberglass with foam core stringers.
Post up some pictures, so we can see what you are working on, etc.
