Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
Go this delivered today and some add'l teak to wrap the remote console. Plus wet out port side teak for under the windows.
My house/car charger crapped the bed.
NOCO Genius GEN5X2, 2-Bank, 10-Amp (5-Amp Per Bank) Fully-Automatic Smart Marine Charger, 12V Onboard Battery Charger, Battery Maintainer and Battery Desulfator with Temperature Compensation​
Visit the NOCO Store
kcassells
Cold up here today so some of the treated teak/oil is sticky and glued eeeppoxy joints are tacky.
Moved to basement to put around boiler.
Playing with the new NOCO battery charger. Pretty impressed with it so far.
kcassells
I've been reviewing and looking for years for various components etc. Ya know I'm in the turtle race and time is not an issue.
The unit costs $139.00 delivered.
Flipped it on this morning and bank 2 took @ 20 mins to charge and then go to repair mode. Bank 1 is still in charge mode. This is a great tool for a multibank battery scenario. I can walk away and feel comfortable that there is no issues charging over lengthy times.
Dang thing was heavy and compact.
kcassells
Got to do port side teak under window and installed. Teak like other side 3 pcs. to make shape. Next or later will be the bungs and another sanding/coat.
Also fabbed up the under pc. of teak/remote to finish up the look. Still tacky so I'll have to wait to complete. Guess it's time to get the boat and shed heater online.
View attachment PTeak 4.MOV
chevymaher
I thought you ended up building one yourself.
I did the side on the boat. But the cheapo charger was what i used to make it. I cant find a pic. But I can stand next to the boat and check voltage and charge. It is right under the boat cover. Outlet is in the boathouse right next to the boat.
kcassells
No problem at all.
I have seen politics on other forums go from funny to some weirdo showing up at a person's house. Gets nasty.
Thanks!
kcassells
Glue finally set up on the teak. One side more than the other was rough saw cut. Cleaned up both sides and picked this side for the face. Needs trim to fit. Cleaned off saw cut and poxy with 60 grit then worked up to 220. Put one coat of stain for look. Probably little more sanding after cut to fit.
BTW...very happy with the new charger.
Just little stuff.
kcassells
Sooooo... Camera was giving me issues with downloading. This weekend pulled off the cover and pressured washed everything and used a soaker. Used dawn soap with the soaker, then pressure washer. No issues with
@Woodonglass famous paint formula. 2050 electric pressure washer.
Wrapped up the teak for the shifter.
Rainy day here all day.
zool
View attachment 372556 View attachment 372557 View attachment 372558
View attachment 372559 View attachment 372561
So you have my old camera? ;)........looking good KC!......Ill start spooling the reels.
kcassells
Yes I do have your ole camera. Still has film in it.
I'll send you the film.
Now it's really my comp. port not making connection, so I take some time at work.
Please do get those rods ready!! It's killin me not to fish or be on the water.
THANKS!
zool
THANKS!
working on it now in the warm attic :-]...
