Mercury 150 Four Stroke charging
MaineTyee
Hi all, new to the forum and need to draw on the expertise here. I have a Lund Tyee 1900 with a 2015 Merc 150 Four Stroke. On a fishing trip in September I slowly started losing voltage and eventually the motor died. Luckily I had a 9.9 Pro Kicker to get me back to the dock. I assumed it was the alternator and bought an aftermarket replacement. I had not run it since putting the new alternator in and decided to start it on the muffs to check the voltage before shrinkwrapping it for winter.
I had to boost it to start, then checked the voltage at the battery and only got 11.3 volts. When checking at the alternator post I am getting 21 volts!
I know 21 volts is too high, and now it seems I must have blown some sort of over protection component. Any ideas? Thanks in advance for any input.
Ayuh,..... Welcome Aboard,...... Let's try the Merc Outboard forum, 'n see if we can get ya an answer over there,.....
MaineTyee
Self diagnosed...need another new alternator with a better voltage regulator, and the alternator output wire has a 100 amp fusible link in it that was blown
QBhoy
Hi. Did you jump start it with a running engine on the other end of the leads ? Doesn’t often end well perhaps.
I have a similar aged 115 merc. The output charge it has is very low when at idle and first started. Takes a wee while to give a charge out. Then it can actually regulate to provide a higher charge at slow trolling speeds, if it needs to. But certainly initially…it doesn’t snow much…unless you wait or give her a wee bit of revs for a few seconds
Ayuh,...... I'm wonderin' whether that's what caused the original problem,..??......
