msd58
- Feb 14, 2003
- 304
Last run of the season. Came off plane and heard this sound coming from under swim platform. Makes sound in forward, neutral and reverse. Any ideas?
Flappers, ujoints and entire transom assembly new 2020. Inside engine bay it's not making that sound. Pronounced sound coming from under swim platformMy ideas are U-joints or exhaust flapper. Is the noise present in the engine bay as well?
Post 1 said does it in fwd neutral and rev.Does it do it when in gear at idle ?
I really should have paid more attention!Post 1 said does it in fwd neutral and rev.
YesDoes it do it when in gear at idle ?
What part of the 2020 job?Check the props to see if they are loose, otherwise need to pull the drive. Hope not, but could be the 2020 job was not so good
I readWhat part of the 2020 job?
Inside not making noise, but outside isFlappers, ujoints and entire transom assembly new 2020. Inside engine bay it's not making that sound. Pronounced sound coming from under swim platform
No Its single engine 28' express cruiserWhat kind of boat is this ? Don’t suppose it’s a formula with the silent thunder system. With baffles and water box in the back of it ?
Everything was done as listed....gimbal bearing is new as its part of the transom assy package when you buy it....to my knowledge gimbal bearings roar when they are going bad.I read
Maybe something was not done but listed it was.
I would look at outdrive since no sound inside boat, but could be gimbal bearing
Looks broken . . .Here's the problem. Pic of gear set removed from upper
