1962 Chris Craft Holiday 20’ bucket list resto
kcassells
Wrapping gifts, cleaning, prepping food, spending money and enjoying the flu. Bah Humbug!
Merry Christmas to everyone!
19073, Newtown Square, PA
Weather App
CURRENT WEATHER
3:50 PM
SunnyDayV3.svg
16‎°F
Sunny
FEELS LIKE
‎-3°
There will be mostly sunny skies. The high will be 27° and it will be blustery.
sphelps
Drivewayboater2
Hey….we are having a heat wave in south eastern PA……it’s 21 here…
had the stomach bug since Friday… couldn’t eat, drink, or merry… Grrrr
MERRY CHRISTMAS TO ALL !
Ned L
Nice project.
I would suggest that if that port stringer is 90+% good then the whole thing does not need replacing.
sphelps
Nice project.
Thanks for chiming in Ned !
It’s just one spot on the stringer . Once I get the motor out we can get a better idea on the damage .
I think jus water collected were the motor cover and deck boards came together .
Do you know how the main stringer is fastened ? I see the large fasteners that come down to the lateral ribs from the top . Would these have been screwed in place from the bottom up also ?
Ned L
I believe those bolts just run down through the frames and that’s it. I don’t think there are any screws from the bottom.
There should be one bolt through each frame. Is that what you are seeing?
sphelps
That’s what it kinda looks like .
So it’s possibly a through bolt?
Or a lag screw ?
sphelps
Small update ..
Been working on closing in the barn .. Got 3 sides closed in and working on the front now . Just used cheap wafer board with multiple layers of paint in the outside . As long as it last a few years I’m ok with it .
The back panels are some plastic panels I had for years laying in the yard . Finally found a use for them .
Gunna have a 12’ x 8’ door opening in front .
sphelps
So does this 6400 lbs strap look suitable for these 4000 lbs chain falls ? 1E9E49ED-8F08-4290-9D98-673EC98590C5.jpegEF207DB0-04F5-403E-BC62-95C0DF839B19.jpeg
considering the 4:1 safey rating, plus the reduction for double wrapping, your fine.
kcassells
Yea Yea....like he said. Great set up Sam!
Make sure the flooring under the posts is thick/reinforced enough to take and hold the weight
for the duration of the lift.
eggs712
Straps are strongest in a basket like yours is rigged, so that's good to go!
