Scott06
- Apr 20, 2014
- 6,866
Cheaper would be junkyard motor, +/- rebuild. Mine cost $180. If you count the value of my time, mine cost $50kAnyone have a good source for a cheap long block ?
Some would probably try and fix it and some would succeed in doing so but im a firm believer in what goes around comes around so I’m not gonna fix it the right way instead of being cheap and pass the boat on knowing what I done!Just curious - could that crack in the jacket within the galley be die ground out and JB Welded if its just a water jacket and hence not under immense pressure, or would that not work?
You need a 96 and up vortec 4.3 link in post 21 is correct OneI’m sure it’s said somewhere else but if I ordered a reman engine engine what numbers would I go by to be sure I’m getting the correct long block thanks in advance
What needs to be swapped to Marinize itYou need a 96 and up vortec 4.3 link in post 21 is correct One
also as outlined you can get a truck vortec 4.3 from a wrecking yard and marinize it
strip it down to a long block and swap everything from your running motor.What needs to be swapped to Marinize it
You need marine head gaskets, brass core plugs, marine accessory drive, marine intake, marine exhaust, marine water pump and marine electricsWhat needs to be swapped to Marinize it
Call michigan motorz im sure they could do a shortblock… but you need to take the heads and have them magnafluxed for cracks or pressure tested As they were exposed to same freezing as the block. Doesn't make sense to just do a shortblock unless you are 100 % sure the heads are not cracked. By the time you check them out you’re probably at the same costAnyone know a good reputable place to buy a short block, and without pulling the motor yet how can I come up with the casting numbers for the block , I have serial number to engine but I do not know casting numbers ! All hell is appreciated
This is the most ridiculous thing ever btw. The hardware was actually not as easy to source as you'd think. Nothing available locally, and I had to buy a lot of packs of 10 when I only needed one type of thing. Cost me a lot of time. You also need a new starter if you go this route, or need to drill out your current one, as the M10 won't fit the holes.The metric block used metric M10 fasteners for the flywheel cover, side motor mounts, and starter bolts, all other fasteners are sae… its about $20 of grade 8 bolts and starter bolts…
Not sure if you are saying my comment was ridiculous or GM putting two types of fasteners on same block...This is the most ridiculous thing ever btw. The hardware was actually not as easy to source as you'd think. Nothing available locally, and I had to buy a lot of packs of 10 when I only needed one type of thing. Cost me a lot of time. You also need a new starter if you go this route, or need to drill out your current one, as the M10 won't fit the holes.
Okay so I can’t see any casting numbers , correct me if I’m wrong but if I take the starter bolts out and see if they are metric or sae then I would know if it is a 090 or 090m ?Call michigan motorz im sure they could do a shortblock… but you need to take the heads and have them magnafluxed for cracks or pressure tested As they were exposed to same freezing as the block. Doesn't make sense to just do a shortblock unless you are 100 % sure the heads are not cracked. By the time you check them out you’re probably at the same cost
rapido marine in fl has had some good comments here as well but their pricing seems maybe too cheap. Here is there link to 4.3s outlining the casting numbers …https://www.rapidomarine.com/default.aspx?p=/engines262.aspx
check your casting numbers as Lou mentions, likely you have a 090 or 090M casting, but any vortec 4.3 will do… if you have the M casting (metric) or someone offers you one dont get hung up on it. The metric block used metric M10 fasteners for the flywheel cover, side motor mounts, and starter bolts, all other fasteners are sae… its about $20 of grade 8 bolts and starter bolts…
Light readingOkay so I can’t see any casting numbers , correct me if I’m wrong but if I take the starter bolts out and see if they are metric or sae then I would know if it is a 090 or 090m ?
Thanks I found it ! It’s an 090 casting , and found short block or long block at mabbco engines in Tyler Texas but after reading reviews they wasn’t what I was looking to see!looky here...View attachment 374823
