Greetings all!
I have a Princecraft 19.6 Special edition 2002 MerCruiser 4.3 MPI. I have had intermittent leaks at the rear transom area. Pulled the engine and transom plate and am down to a naked transom. My question is, when installing the new transom gasket, should I apply a bead of 4200 to the gasket on both sides to seal the foam gasket to the boat and the gimble housing. I have not found much info on what it requires. It looks as if it would have been done at the factory originally my boat would have not leaked. Thanks for your input in advance!
