rickasbury
Master Chief Petty Officer
- Jul 13, 2011
- 817
So, have been working through some issues with fuel...I think with all the cranking,or not getting water to the pump I fried the impeller. My 350 mpi is closed cooling. For water I have the merc foot and a thru hull- both hoses go to a strainer and then to the pump. I have it home on a trailer. When I got it running I jumped out of the boat to make sure water was flowing- it was not and the impeller came apart. It was a few years old.
My all brass pump had been scoured so I had sourced an after market impeller with two wear plates which seemed to work fine until the above happened. That company shut down so I could not buy the same set up. So, I ordered from merc and impeller with a wear plate for the pump side. I see another version of the pump the brass back plate that has a wear plate- mine is completely flat. So, to deal with the groves on that side I set up my belt sander and ground it back smooth. Maybe a 32nd or probably less of material. It went back together fine I think- plate sat up on the seal as I tourqued the two together. So once installed, still no water. I have lost the impeller before running on muffs before so I really try to avoid doing it...so I'm wondering how much of an air leak would cause the pump not to pull? The strainer had water in it, not full but it did cover the intake port inside the strainer. So while I had the thru hull closed, as far as I know, could it still be possibly leaking? Seal on the strainer? Would having the thru hull closed could that set up some sort of lock to where water won't come in? I'm really stumped! I think I will take it to the ramp and see if with everything in the water if it will prime and pull water, assuming I did not trash the impeller again. The temp gauge works off the coolant and not the raw water correct? So if it starts to run hot I can shut it down...any clues here? Anything else I can check? I pulled both ends off the heat exchanger and no impeller parts are in there..I do not have the cool fuel program...in the pump seemed to be most of the impeller.
