maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 801
Working on a 1995 evinrude 40 hp tiller. The fuel primer isn't getting power. I tested the switch is good and the primer itself is good. I tried switching to a different rectifier but same thing. The rectifier I used came from another motor so I'm not positive that it is good. Could a bad stator cause no power to the purple wire on the terminal block for the primer? A way to test the stator?
