MaxGlide
- Aug 20, 2020
- 194
Honda BF7.5, serial number 1602841
Initial problem would on run a bit with choke and die out.
Took carb off, used carb cleaner and compressed air to clean mixture screw opening, screw to left of that. Removed bowl, cleaned main nozzle, including tiny holes. Cleaned mini filter in fuel pump, main filter seems good. Made sure no leaks in fuel lines.
Now motor runs better when I rev the throttle, but dies out when rpms drop down (before only ran with choke full on)
Could it be fuel pump?
Should the inline fuel filter level drop as shown in picture? I pump it full before starting it.
