Bt Doctur
- Aug 29, 2004
- 19,463
All I know;
Was being transported by water when the stbd motor, stbd riser/elbow had broken the water inlet to the elbow. Captain stated a Guardian shut down and came in on the other engine. R/R the water fitting connection .
Motor does crank, electric fuel pump is heard, but motor will not run.
? Do these motors shutdown with a trouble code for an overheat and do you need a laptop to correct the situation
Thanks
Thanks
