As most people know the grease tube on these outdrives is a pretty poor design. My gimbal bearing failed after one season due to the tube falling out somewhere and allowed water in the bearing .... what a headache. Well as always its just about time to boat in water and low and behold my gimbal, bellows project took a turn because of this tube. Nobody has them in stock locally and a week out and $35 for tube and $9 for grease fitting. Don't have time figured try to make something a little better. So here we go in case anyone else runs into this...
What you need:
Jb Weld marine weld $12
1 foot of 3/8 tubing $ 0.79
1/8 45 degree grease fitting $1.89
1/4" x 1/4" barbed adapter BHB-197NLB $5
1/4" X 1/8" bushing BF-738NLB $5
I cut about 4 1/4" piece if tubing shaved down one end and roughed it up. So it would fit snug into gimbal bearing housing
Put some JB weld on it carefully not to get into tube or on inside of bearing race. Let set for hour.... perfect time for a beer or 6....
On the other end I stuck barbed fitting on tube, threaded in bushing and grease fitting using Teflon.
Seems to work great and hopefully will last a long time. Will update this later after it gets in the water. Hindsight I wish I made tube just a little bit longer to put hose clamp on barb fitting area.
I read the thread about tapping the housing which I had no luck as couldn't get the tap in straight with hydraulic lines in the way. But that is also a great fix if you have the room.
To save anyone time if you want to stick to OEM stuff. The original part# for tube is 3852564 and grease fitting for it is 3852121.
What you need:
