1985 Century Mustang
- Mar 9, 2023
- 618
You can buy the bearing but as outlined above you will need the tools to shim it properly.This is the part I need. I think it's called an upper roller bearing. Can this be replaced or do I need to buy a whole complete unit?
Also need to disassemble and wash out the lower as metal shavings will move between them.
The upper bearing was the clicking noise you heard in the running video you posted on your other thread.
As mentioned the quickest plug and play is a SEI gen one drive as basically you are looking at tearing down the entire drive
Could be but there is no way that bearing u posted pics of wasnt making noise. That was about to grenade. Might just be the camera angle but would check the gear teeth for wear before putting money into it the metal from the bearing went some where in the driveThanks for the info. FWIW, that clicking noise was most definitely without a doubt the coupler. The sterndrive was removed before I removed the engine, and still made that clanking noise. So I replaced the coupler and the noise vanished. The coupler was loose because of an out of aligned engine to sterndrive.
I think i caught it at the right time. The gears don't look too bad.Could be but there is no way that bearing u posted pics of wasnt making noise. That was about to grenade. Might just be the camera angle but would check the gear teeth for wear before putting money into it the metal from the bearing went some where in the drive
