Overheating
I have a 2003 mercruiser 5.0 carborated. It started with my port riser getting warmer then the starboard and the alarm went off then i had replaced the impeller the water circulation pump and the thermostat and the risers were cool again. But the thermostat was hot and still sending an alarm. The risers and manifold's were replaced last year and I am still slightly overheating at the thermostat. The alarm starts to beap around above 2000 rpm then stops beaping once on plain. Manifolds and risers feel cool to touch thermostat housing is hot to touch. Doesn't seem to be a head gasket no water in oil and engine doesn't miss. After I turn it off I let it sit to see if risers are leaking down into cylinders to check if it gets hydro locked but it starts right up. It runs about 175 to 190 when getting ready to plain. At idle 175 on plain 180 185 wich is still to high. Please help I hope you have enough information?
dubs283
Possible failing engine circulating pump?
Are the hoses attached/routed correctly to/from the t stat housing?
Would like to guess blockage somewhere but with manifolds/elbows being cool it seems like not enough water supply/exit from the block. Pretty sure your 2003 setup does not have check balls for the elbow water supply
Yes it has check balls they are clean and are working properly.
dubs283
They are not
The check balls are allowing too much water past at lower rpm. There's not enough supply to the circ pump due to water exiting the exhaust before the circuit pump hose at the t stat housing
Remove the balls, turn them around and re tension the springs. Pretty sure it'll aid in blocking enough water so the circ pump doesn't starve
They are not
I will try that. Make sense. How tight do the balls need to be they feel pretty free.
dubs283
The balls need to be seated in the barbs at rest
Shouldn't take much effort to move them off the seats but it's important that they seat with little/no gap
dubs283
What is the condition of the drive? Where the sea water pump is located
Corrosion on the gear case housing can cause overheat at certain rpm
I just had the sea water pump replaced 2 weeks ago after it started this temp issue. The outdrive is in amazing shape. I flush the engine every trip. For almost 20 years old the outdrive still looks brand new. I keep it on a trailer.
I had a marine shop do it. But it had this problem before they replaced the impeller. They use nothing but OEM parts.
dubs283
With vintage posted by you of roughly 20 years ago I'm assuming alpha gen 2
A few gen 2's that have passed my way have suffered from corrosion at the casted dam aft of the water pump assy between the sea water pickup and exhaust cavity. This is including fresh water operated raw water cooled.
With no eyes on this area I can only speculate based on my experience. You may need to remove the drive, split the halves and inspect
