Marinepower Vortec 4.3 White/Red wire jumped together
nmelche
Can anyone help me figure out what this wire is for and why the previous owner has them jumped together? Not sure if it’s a white/red wire. That’s what it looks like to me but looking at wiring diagrams I’ve only seen a yellow red wire mentioned. Thanks!
Ayuh,..... Welcome Aboard,..... Is this a Marine power, or Mercruiser motor,..??
Where abouts in the harness is this,..??
nmelche
Marine power. I’ll have to take a closer look at the harness later to tell you where it is
alldodge
Looks more Yel/Red to me, and if so could go to neutral safety which is bypassed
alldodge
With a inboard there will be a switch on the trans mission.
If used on a I/O then leave as is and go from key start pin thru shifter then to slave relay
Also moved thread
