I couldn’t lower my motor, it would only raise up. I replaced both solenoids. Now it’s acting strange. It currently will only raise up, not lower using the top of the switch. If I swap the blue and green wires, it will lower and won’t raise, still using the top switch. Bottom switch doesn’t do anything.
If I swap the “little” blue and green wires then I get the same behavior, only using the lower switch.
I can’t seem to get it to work normal (lower switch lowers motor, top switch raises motor). I feel like it’s a wiring thing or something considering the issues. Thoughts?
