1985 Century Mustang
- Mar 9, 2023
- 618
Today after a 5 hours on the water, I started losing acceleration as it bogged down, some times almost stalling out. The engine took a few seconds to shut down when I turned the key off, it was sputtering for a second or two and then it shut off. Never did this before.
When I got back, I removed all the plugs and they were perfect. This carburetor was fully rebuilt just several months ago, and I didn't have any issues since today. However when I rebuilt the carburetor I couldn't remove the plunger when I did the rebuild, so I cleaned it as best as I could. Maybe that could be the issue, who knows.
Before I remove the carburetor I'd like to know if a fuel additive might help. The water separator filter is pretty new, and I checked all the fuel filters, which looked fine.
What should I check next, and would the seafoam fuel additive do any justice? I get gas on dry land from a reputable gas station that sells and moves a lot of gas, never had issues w bad gas at that station. Your thoughts.
