Making engine beds
markhodges78
Ok I removed the 3.0 engine and set an old 4.3 engine I had over in the boat just to see what it would look like... I believe the 4.3 is going to fit nicely. Now it's time to start cleaning the old oil and grease out of the bilge area to get ready to start making the engine beds ...
markhodges78
This is the location of the engine beds. Should I level this area out with glass to start with a flat pad ?
My next question is should I use a 6x6 to make the beds or should I use plywood sandwiched together and stacked up ?
todhunter
Canoeist
I would just laminate with poly resin, and maybe a sheet of 1.5 oz CSM between each layer. If you want to get fancy, laminate a piece of rot resistant wood (I used Sapele) in between your plywood, and position it so that the lag bolts go into that wood only.
markhodges78
I like the idea of the rotted resistance wood but how do I make it to where the lag bolts on go into that wood .. should my laminated wood beds be positioned stacked on top of one another and the leg bolt go down through the different layers or should they be positioned side by side and the straight up and down
Thanks in advance
Scott06
Thanks in advance
Stack them layer by layer would use construction adhesive then bed that whole block into the hill and tab in with fiber glass.
Put the engine on it and get an alignment I used a really long 3/8 spade but at a slight angle to drill through motor mounts into block of wood put some sealant like 3 m 4200
markhodges78
1/2 plywood or 3/4 ? Sorry for all the ?s
Scott06
Doesn't matter what ever you have, Its just a built up block of wood in the end. Don't overthink it the boat and driveline is less precisely built than one would think.
todhunter
Canoeist
Thanks in advance
Start reading my thread from here and you can see how I did mine. The pieces of wood are vertical so the lag only penetrates the sapele. The two pieces of plywood are totally isolated from the sapele by way of CSM between the layers.
markhodges78
My engine beds need to center out at 6 inches finished it looks like so how much should I allow for the glass layup?
markhodges78
Not center out I don't know why I put that what I meant was the height needs to be 6 inches finished. Do I make my block 5 3/4 and make up the rest with the glass ?
markhodges78
Hey todhunter I looked through your thread but didn't see if you posted. How many layers of 1708 should I cover the mounts with? I believe if my math is right 8 layers would be about 1/4 inch
Thanks Mark
todhunter
Canoeist
Thanks Mark
Mark, I only did 2 layers of 1708 over the mounts. The original mounts in the boat (which were completely fine, but I had to rip them out to replace the stringers) only had one layer of 24 oz woven roving over them. So 2 layers of 1708 was more fiberglass than original, and the original mounts held up fine.
markhodges78
Thanks
markhodges78
My mounts have been peanut buttered in and it's currently curing but after it's cured should I tab and cover at the same time or tab let set up and then glass in ?
todhunter
Canoeist
A wet-on-wet application will almost always be stronger. It shouldn't matter tabbing or covering first if you prepped the mounts well (fully covered in resin, no dry spots), but I would probably cover first then tab.
flashback
Get the stringers in and glass the whole thing as one structure.. much better than pieces... IMO
