Totally awesome the engine is running normal again for you.Thank you all!! We are good to go again!!
Thank you “muc” for your Chris Craft expertise!
After readingTotally awesome the engine is running normal again for you.
So please, in detail, what did you find to be the actual problem as knowing that type of info afterwards helps many, many others including the members here trying to help you too.
Thanks.![]()
After reading Muc’s reply, we looked for the hull thru that we would attach the Fake a Lake to. We found it and the Sea ****. As he pointed out in the photo, we had been running 1 hose with ear muffs at the back thinking we were running water correctly. Every local mechanic and every forum I posted on before this one made us out to be idiots that we didn’t know what an impeller is, that it’s impossible to have 2 impellers, etc. We may well be ignorant of several things about this boat, but we know for sure what an impeller is and that we had changed 2 of them. Twice. Once in 2020 and once this summer. The difference is we put the boat back in the water in 2020 to test it. This year we attached the ear muffs and it was still heating up because we weren’t using a Fake a Lake on the hull thru. The impeller that’s a nightmare to change was not getting any water. Unfortunately, we had run it several times that way while trying to figure it out.Totally awesome the engine is running normal again for you.
Thanks.![]()
