Hello all. I have a 1973 Johnson 9.5hp motor that I have been using for some time. The motor idles fine and starts easily however only gets about half power, and only reaches about 10kmh in a 14ft john. I have figured out that the motor has been running on only the top cylinder, however at higher rpms the bottom cylinder begins to work in short stutters.
I have replaced the ignition coils and aligned them and checked the point gaps and condensers and all seems to be working fine. At first the new coil for the bottom cylinder rubbed the flywheel how ever I adjusted it and it no longer does. The pressure for the bottom cylinder is about 65psi and the top cylinder is about the same. The carburetor has been cleaned out well. Before I open the engine itself, is there anything else that could possibly cause the bottom cylinder to function like this?
