Hey Guys,
Having some ongoing issues with my Force.
Here's the summary:
Motor was dying at low RPM when shifting into gear. Then:
-Motor started not only dying at low speeds, but high RPM.
-I'd push the throttle and it would just die.
-Would start up and idle fine.
Today I went out and
-Motor wouldn't start at all.
-Hooked up an external tank and after 2-3 mins of cranking it over, it started, idled and when throttled ran great.
-On the way back to the dock the motor died out at low RPM's (On the external tank still).
Some #'s
Motor idle speed is set at 800 RPM.
Compression tested last year:
Cylinder 1 - 130
Cylinder 2 - 145
Cylinder 3 - 150
Cylinder 4 - 135
What should be the plan of action from here?
I was thinking running a bottle of Marine Seafoam through it and checking the Fuel/Water Separator.
After that, what's the best way to check if fuel lines need to be swapped and if the fuel vent is blocked/not working?
Here's the summary:
Some #'s
Cylinder 1 - 130
Cylinder 2 - 145
Cylinder 3 - 150
Cylinder 4 - 135
