jitterbug127
- Feb 6, 2023
- 656
Not a problem at allDavid thanks for being so helpful!
Out of time massivelyHow does this spark look to you guys?
Key is snapped look at the picture i blew upKey looks fine to me.----And use no grease when fitting the flywheel.----Must be clean and dry.
Ok so can you take out the key does the bit from the top of the crank that is flush with the crank also come outWhat is the solution to fix this? I don’t know where to go from here?
I'm sure its not he needs to send a picture of the flywheel in place located to the key to see if it makes contactI thinks the key is OK
I do too. It doesn’t appear to be broken to me. If it is I’ll swap it at a later time. I don’t know what to do to fix my motor from here.I thinks the key is OK
Pitting at the top of the crank and is this top part of this a part of the key look at the picture of your flywheel you have a misshapen sharp pointI do too. It doesn’t appear to be broken to me. If it is I’ll swap it at a later time. I don’t know what to do to fix my motor from here.
