MNhunter1
- May 12, 2014
- 1,104
I'm considering converting my rollers over to bunks. I have a low slung drop axle trailer w/ only 6" of ground clearance. Is there a bunk bracket available that can be mounted on the cross member that will not protrude below the cross member and catch/snag/drag as the lowest point of the trailer? I am familiar with the vertical L brackets, but would like to run 2x6's horizontally due to my available space at the forward/angled cross member. A standard bolster bracket w/ adjustable bracket will work fine at that location, it's just the transom location that is perplexing me. Most examples I have seen with a similar arrangement, low ground clearance and bunks, have welded on brackets for the bunks to rest upon.
I have 10" of space between the transom cross member and hull, and 4.5" of space at the forward cross member. I could raise the overall height a bit, but it's rests on the trailer rather nicely as it is currently configured.
