rickasbury
Master Chief Petty Officer
- Jul 13, 2011
- 831
I've had so much stuff apart but I can't remember the cables for shifting...I had my motor out a while back and replaced the lower shift cable, 350 mpi/bravo lll. At the ramp today and pulled off the trailer and parked her at the dock and parked the truck. Back to the boat, started up and cast off- no forward or reverse . Throttle works. I first thought I blew the coupler ( which has been replaced) or trashed the bravo lll (300 hours). I had it running once I got pulled back to the dock and moved the shifter- I can see the throttle moving but I don't see the shifter mechanism moving..there is a separate cable for throttle and shifter right? I replaced the shift handle because the trim switch was not working but I don't recall taking any cables apart...how does that push button work that disengage the outdrive to rev...I had just pushed that, could it have gotten stuck?
