rickasbury
Master Chief Petty Officer
- Jul 13, 2011
- 817
I guess the title is mis leading- I found after I put my outdrive back on without the proper adjustment it's hard to shift.
I recall on the bearing puller there was a way to set that end of the cable and then there is another tool to set the other end of the cable. I believe there was a work around for the tool up top with a measurement. I'd guess there be one for the lower too.
So my delima, and I know the correct answer, can I play around with the adjustment up top and get it shifting smoothly again?
I probably need to yank the drive and check the alignment from when I put the motor back in- it was not pleasant doing that by myself...
Can I pressure test the outdrive myself? I have a pancake compressor I can set the pressure on...I think I have a couple of different pressure gauges..I don't want to blow 5 grand apart...
