I have two Force 85 motors. One is a US Marine version without factory tilt & trim, that has had a CMC PT-130 added, which has been a thorn in my side for the past 3 weeks - leaking down internally, takes forever to lift motor then drops it back down in seconds, and still doing it after replacing every o-ring in the thing and seal in the thing. This is a good running motor that was on a junk hull.
The other motor is a Mercury version, with factory dual cylinder tilt/trim, that came on the replacement hull. It was run without oil in the lower unit, which caused the LU to seize up, but the engine was still good. Figured out the hard way that I couldn't simply swap the LU from the other motor over to it.
So I swapped the whole USM motor over to the replacement hull, with the CMC unit, then found the issues with the CMC afterwards.
I was looking at the two today, and it looks like I should be able to just swap over the factory T&T assembly from the Mercury version to the older USM version? It looks like all the pivot points are in the same place for the tilt cylinders, the extra pad that the trim cylinder pushes against is there, bolt bosses are there, etc.
Is this as simple as it looks, or is this going to turn in to another nightmare for me?
