I have found a 12 ft aluminum boat with aluminum trailer and a 2021 yamaha f9.9 short shaft motor for sale for $5000. That seems like a very good price and I wanted a small boat for fresh water fishing. I was hoping the outboard would double as a kicker for my larger boat pictured below. I would get a bracket that could be raised and lowered. Position it roughly where the tie down u bolts are on back which is 18 inches from bottom at that point. The water line on transom is 9 inches at that point. I don't care if I have to remove the trim tabs as they are not powered anyway. I'm most concerned with whether the motor will sit too low to the water when in use and maybe get swamped. Not worried about steering as I would tie into main engine to steer from front. Do you guys think this is feasible or is a long shaft motor a must?
